Help finding part number
Old 01-28-2013, 10:57 AM
mgavin2's Avatar
Default Help finding part number
Hey guys (and gals!?). I recently had a family member purchase a klx250 and through the process of going over it ran into a little snag.
One of the axle pinch bolts was sheard in half resulting in just three nuts holding the pinch plate on. Completely unsafe I unscrewed the bolt out and looked at a parts fiche only to find out that that part is not listed?
Anyone know the part number for an axle pinch bolt? Or a compatible on from another make model?
Thanks a lot!
-Mike
Old 01-28-2013, 11:17 AM
Those were studs with nuts right? I replaced all 4 of mine with bolts. Havent had a problem since. One of mine broke also. I believe they are the same bolts that hold the plastics on. Same threads. Not sure on the length.
Old 01-28-2013, 11:20 AM
If you want the original parts its on the front fork fiche .
Ronayers.com Microfiche Kawasaki>Motorcycle>2006>KLX250S>Front Fork(2/2)(H6F)
Wait, you can buy the nut, but i dont see a part # for the stud. Id just put 4 bolts in there.
Old 01-28-2013, 11:29 AM
mgavin2's Avatar
ems from rufcut riders? Man you get around... Actually went for my first ride with a couple fellows from there at camp horne. Fun bunch
thanks for the suggestion for the studs. The parts fiche even has the fork turned away from the viewing angle as if they don't want you to even see the studs. Great suggestion for using some bolts instead. Got to go measure...
Old 01-28-2013, 11:57 AM
HA!!! Yea thats me. RCR is a great group of guys. Hope to see you on some future rides.
Im betting the M6X20 bolt will work. Like the longer side cover bolts, try it out, take out the upper side cover bolt, that also holds the seat on. That should be the right length.
http://www.ronayers.com/Fiche/TypeID...rs_Chain_Cover
part# 92153-0502
I use a local do it best center for all my stainless hardware needs, i found lowes and home depot sucks for metric and S.S. If they have it, its hard to find.
Old 01-28-2013, 12:02 PM
If ya need any other help with the KLX let me know. Ive had mine since spring of 2006. Pretty familiar with it.
Old 01-28-2013, 03:11 PM
ol'klx-er's Avatar
Don't know that I would use a bolt there. A stud means that the threads in the fork aren't in play when removing/installing the axle.
It can be done but be extra careful so as not to STRIP the threads in the fork.
Old 01-28-2013, 03:15 PM
My bike has been like that since the day i picked it up. A stud was broke from assembly.
Old 01-28-2013, 04:32 PM
RockabillSlapMatt's Avatar
Old 01-28-2013, 05:38 PM
cmott426's Avatar
The 09+ are different in this area then the 06-07. The 09+ just use a bolt.
Quick Reply: Help finding part number
