Help electrical problem
Connect the two wires that go to the clutch switch together. While you're at it bypass the sidestand switch as well (connect the two wires together that got to that switch). Understand that with those safety switches defeated you'll have to think for yourself. Pull the clutch lever any time you crank with the bike in gear. Make sure the sidestand is up before riding away.
And check the kill switch as well.
clogdoctor
04-12-2011 07:01 PM
