Help! Dyno jet install
I put the the o ring, washer, spring, then the kouba like it said. I dont think I was doing full turns. I don't want to pull the carb again to put it on unless I have to. Thanks
It wouldnt be so bad if I didnt have to remove the pelican case from the from the rack, the rack from the frame, the plastics from the frame, the seat from the frame, the shrouds from the tank, the tank from the frame and then the carb. I will definitely try the carb "in" method when I change it out next time.
