Help - Carb sputter - backspit/fire
Help - machine fires up... starts to idle fine... all the sudden you give it throttle in neutral the carb shakes and almost "burps", when adjusting idle... it sometimes sounds like its going to take off as if it were being choked for ever.
When I shut down machine... the overflow line on the carb starts leaking like hell until i isolate the shut off valve.
I had gummed up float valve... assume now that its not seatings and all the problems are being caused by to much fuel.....
Help?
Help?
110, 2012, backspitting, burp, carb, carberator, carburetor, choked, cleaned, idle, kawasaki, klx, motorcycle, sounds, sputter, sputters
