HELP! BIKE STALLING AT IDLE WHEN I GIVE IT GAS
RE: HELP! BIKE STALLING AT IDLE WHEN I GIVE IT GAS
First of ditch the kdx snorkel. Your base line settings should be 128 main, clip #3 from the top stock pilot and 2.5 turns out on the mixture. Also I would replace your spark plug, I know they say they are good for a gazillion miles, but I have seen many a hundred thousand plus dollar cars come in on the hook with fouled plugs. And it sounds like your plug has taken a beating. My two cents worth hope you find the problem.
I HAVE DONE ALL THAT WITH THE EXCEPTION OF THE AIR BOX. BUT I DID NOT END UP REMOVING THE AIR BOX BECAUSE THE PLUG LOOKED ON THE LEAN SIDE. AND WITH THOSE SETTING I WAS IDLEING EXTREMELY POOR.
Mr.S7
11-21-2006 12:45 AM
