Help with 09 klx250s
Old 03-22-2010 | 11:17 PM
jwatts's Avatar
Also, if you know how to run a LATHE, you can pick up a cheap oem A/F screw and turn a **** on the lathe,then silver solder it on. I had a hard time finding a adajustable a/f screw for my 09'
Old 03-22-2010 | 11:36 PM
canklx's Avatar
I wouldn't break in your bike using the factory recommendations. There was a thread here not long ago addressing the break-in topic, but I don't remember the title. I broke mine in as recommended by Kawi, but that was before the thread came out. It took a very long time and sounds like it was not the best way to do it.
You'll enjoy the mods when done.
Old 03-22-2010 | 11:44 PM
jeepsnmore4x4's Avatar
Thanks all for the help! This site is A+! Keep ridin! Anyone needs skidloader help ect. hit me up.
Old 03-22-2010 | 11:45 PM
Or jeep help. I'm also an amsoil dealer.
Old 03-23-2010 | 02:03 AM
scottma978's Avatar
i did the just about the exact same mods as you arer speaking with 7 miles on my odometer. it did make a difference....though not enough for me...I did the 351 kit along with some further jetting at something like 13 miles on the odometer...lol. now it's awake!
good luck!
Old 03-23-2010 | 12:26 PM
armycopter's Avatar
Originally Posted by jwatts
I also own an 09' and i waited till about 500 miles then i put a fmf powerbomb-and q4 silencer ,moose jet kit,and a twin air filter. The power is great. Read the instructions w/ the jet kit (very simple) and you will have no problem. You will be satisified. also check the JETTING forums and you'll find tons of info. Good luck and congrats on the bike.
Where are the "Jetting forums?"
Old 03-23-2010 | 01:44 PM
Army...here's the link to the jetting forum attached in my pic.
Old 03-23-2010 | 07:59 PM
mxmidget's Avatar
I can't seem to find it no matter how hard I look Could you tell me specifically where the air/fuel screw is
Old 03-23-2010 | 08:05 PM
canklx's Avatar
It's on the bottom of the carb near the back. There is a round post that protrudes down below the rest of the carb body. This is where the screw is located under a plug installed from the factory. The plug needs removing to access the screw.
Hope that helps.
Old 03-23-2010 | 08:16 PM
Look here, a lot of good pics showing the parts of the carb and what to do when re-jetting
http://hmfracing.com/forums/showthre...?t=1617&page=2
Dan
Quick Reply: Help with 09 klx250s
