Hard time Starting after a Ride
Ok..Hears the deal,Just got the bike Jetted,runs great,no problems high/low RPMs all great...no problem cold starting anymore,pull choke fires right-up..So go for a ride shut it off and now a REAL hard time turnning over,crank crank finally starts shut it off starts right up...hmmm..It use to fire right up after a ride...What has changed?.I was thinking its Hot,but why would it start right up after it Does start.."still Hot" I havent tried any tricks yet...twist throttle push start...Soooo anyone..Thanks....275 mi...brand new
Only has 275mi...FMF full system..kdx snok..Uni..125jet..like said runs great,cold start no problem anymore..nice..But I dont buy the hot start forever start..Like I said Once it starts I shut it off and it fires like a shotgun everytime... vapor lock...no gas.....I will try turning the Throttle next time...
Well..went for a quick 10mile..to see whats up,and didnt start,give it a little 1/4-1/2 turn and left it there,and she fired up...guess she likes some gas now to fire...so cool..hope this helps others...
Yeah, I found on the CV carb, to start it cold I had to use the choke and not touch the throttle at all. Then when the bike was at running temp, in order to start it I had to not touch the choke, but give it a little bit of throttle while cranking over.
Exactly the way it is for my bike (running CVK34 carb). Both before and after the camshaft mod. I reckon that when the bike is hot the pilot circuit needs to be "woke up" with a little throttle airflow through the carb.
On mine wich is jetted for stage 2 but the starting jet isn't drilled it was a matter of learing how to start the bike. When hot it likes to have the throttle twisted and she will fire. I ground on the starter alot until I learned what it wanted.
