Hard Starting Cold KLX 250S problem Resolved
RE: Hard Starting Cold KLX 250S problem Resolved
The only issue I would have is cutting a hole in the rubber carb boot, if that leaks, the bike probably isn't going to run too good at all..and I suspect a new one is surprisingly pricy....I wonder if there are any in-line primers small enuf for the 1/4-inch gas lines? hmmmm maybe I'll surf the web and see
Okay..did a little searching of the primer kits for the Keihin carbs and it looks like they are supposed to replace the choke? BUT I think the DRZ400 has both, so i will have to take a closer look at my riding buddy's DRZ400 and see what is geared up to his carb, but i would be willing to ditch the choke to fix the cranky start thingy for less than $20if that's what has to happen
Turning off the petcock and running the carb dry when you shut down will do the trick. Aslo, you can drain then refill the float bowl in you forget to burn the bowl dry before shutting down.
It's always nice to see an alternative though and it's a bit quicker than draining the bowl if you get in that situation.
That is a neat job but I'm sure you will have a leak in no time in that carb boot[:@]I ran NOS on a couple bike and we drilled and tapped the aluminum to install the nozzle ....a lot of bikes have a vacum tube made into the carb boot witha cap on it ....If it leaks you will just have to buy a new boot ......I would look for a threaded coupler with a nt pinch nut and washer on both sides that way you could mount it in the boot better I'm sure some one makes such a thing check into Nitrous system parts I know they you a lot of dry systems now and pump into the intake air hose on a lot of sport bikes just and idea....
So all that is easier than running the gas out?
What a fool I am to think that pressing a primer button once is easier.
I don't get it.
Jetting is pretty neat too.....the only problem is is that sometimes it works, sometimes it doesnt.
The only fix than actually works well most every time is to change out to a pumper carb. Kind of expensive though when the reason it works is because it sprays a load of gas into the chamber when you goose it.
Wont a primer do the same thing though?
PS: Took me 20 minutes to install.
Its a good idea. I've thought about it before. But my KLX only gives me hard starting problems when its 32*F. Anything above, it will start with the choke.
It might be a project to invest in if you every have to replace the fuel lines.
ORIGINAL: 4SEVEN3
Its not that hard.....maybe wrenching on cars for 9 years, then wrenching on bikes for 2 years I see things a little different......I can have my carb out on the benchin less than 15 minutes, taking my time.[sm=icon_stickpoke.gif][sm=lildevil.gif]
Seriously though, to get access to the plug, all you need to do is rotate the carb in the mounting boots, if your not changing jets you really dont have a need to remove the carb.
I've changed the jetting entirely on my stock carb (and yes adjusted the pilot screw as well) and it makes no difference in the cold start performance.
There is obviously some fundamental problem with the stock carburetor - a number of theories have been suggested.
The fix for me is going to be installing my TM36-68 pumper carb...
ORIGINAL: pullin_gs
Turning off the fuel and waiting around to let the bike run dry after I ride, only to have to turn the fuel back on when I ride again?
Niether did I....I love the "turn the bike on it's side" trick best though.
I don't get it.
Yeah Deej that's a bad idea on an air cooled bike to do that.As someone mentioned about the primer for the carb in a previous post....I had suggested this in our master post on this problem.My Honda atv uses the same carb but a slight difference in that it allows a primer **** on the right hand side of the float bowl.This is the sure solution IMO.I have not run my Honda since october and i can bet my next paycheck that 2 pumps of the primer and pull the choke and she will fire right off to a nice idle....It has always worked.My klx on the other hand? I never had a problem.It sat for 5 weeks while i had my cast on for the second time and i went out and turned on the gas and pulled the choke and hit the button...bbbbroom....off she went...and it was about 20* out too not a problem.I also have my pilot out 3 1/2 turns too ....I do know that with a #40 pilot i never needed the choke at all right through november (temps in the 30* area)....but it drank gas like a pig with no real benefit in power.
Good suggestion for a fix though.Those fuel hoses should be fine I ran them on my shifter kart for years and never had a problem....they will harden after about 2 or 3 years though but you can get a 20 ft. foll of it for 15 bux.
