Hard/no start, possible fix
Old 10-11-2007 | 09:43 AM
MaverickAus's Avatar
Default RE: Hard/no start, possible fix
Carbs great, it's a little lean on the main jet which I have to fix. It's chalk and cheese to the CVK, easy starting, instant acceleration, no return cable, whats not to like? About the only thing I like with the CVK over the TM33 is the CVK was a little smoother when getting on and off the throttle, like when your idling along in traffic and changing gears. And the best thing is thanks to Bill it was easy to fit [8D]
Thanks again Bill
Old 01-26-2008 | 08:28 PM
MADDOG2007's Avatar
ORIGINAL: MaverickAus
Since I put on my TM-33 I have no problems starting
What is a "TM-33" ?
Maddog
Old 01-26-2008 | 10:09 PM
Try this Maddog http://www.motorcyclecarbs.com/Mikun...retor_C147.cfm
Old 01-26-2008 | 10:12 PM
klx250s_rider's Avatar
It's a Mikuni TM33 carburetor.
Old 01-27-2008 | 12:25 AM
dacoontz's Avatar
I live in SLC, UTand the temps have been around 10 degrees, and sometimes less. I have had start problems from the get go and charging the battery did nothing other than prolong the torturous start. Since I have tried the tip to the left thing which usually ends up spilling a little gas out of the machine but ends up working perfectly with a quick start up. I also did the running the bike out of gas thing with the extra choke and run for another 5 seconds until it is very dry and that works well too. And this is with 3 to 4 days of 0 to 20 degree temps while my bike sits in the unheated garage and not charging the battery. Dacoontz.
Old 01-27-2008 | 12:42 AM
kx slaughter king's Avatar
ORIGINAL: klx250s_rider
that thing's crazy!!!
wtf is it?
a float and a pump or some ****?
Old 01-28-2008 | 06:10 PM
mooredan's Avatar
I only had the the hard start problem with the Keihin CVK34 carb. I haven't experienced it with either the Mikuni TM33 or TM36. It appears that this problem is isolated to the stock carb.
Old 01-28-2008 | 06:18 PM
vfrpilot's Avatar
ORIGINAL: mooredan
I'll have to put my +2 in here! No problems after the carb change.
Old 01-28-2008 | 07:30 PM
Well that's not a fix in the sense that its free.[8D] Shutting off the gas......free
Old 01-28-2008 | 09:34 PM
LearjetMinako's Avatar
Can't believe so many are having problems with this issue. I can leave the KLX with the pecock on for 2x weeks and it will still start right up with a little choke. Cold weather is another issue. Once it hits 32*F, I'm screwed. Itwill crank till the battery dies.
Quick Reply: Hard/no start, possible fix
