handguards don't fit
Old 03-29-2007, 06:44 AM
johnnyz62's Avatar
Default RE: handguards don't fit
I have the Tusk bars and guards and it was a struggle to get them together. I even had to cut off the inside end of the left guard because it was chewing up the front brake line. It seemed like the best way was to get all of the bolts started then tighten each one a bit at a time to pull everything together. It takes some work and patience, but in the end well worth it.
Old 03-29-2007, 06:57 AM
secondclasshero's Avatar
do a search on the topic. There are a few people in the forum plus my brother and I that have these gaurds on with explanations on install and pictures of them on. I installed mine and my bro's his on stalk bars and mine on tusk bars with no problems. Check em out. If you have any questions fire away. https://www.kawasakiforums.com/m_117535/tm.htm
Old 03-29-2007, 12:09 PM
everything that i have done to this bike hasnt gone as planned, and needed some tweaking.... just how it goes....
Old 03-29-2007, 07:02 PM
I drilled out the bars to install the Acerbis handguards.
Old 03-30-2007, 11:42 AM
Truckman's Avatar
Same here but i slammed the bar weights into the bars...The mounts with the acerbis enduro guards and the bar weights slammed to the inner parts of the bars eliminated all bar vibration in all.....I didn't get new bars yet but it works good.....Also i used a piece of 3/8" fuel line cut in half and zip tied to the brake line cover to eliminate any rubbing of the line.
Calisaki250
07-01-2014 01:05 AM
07-03-2010 07:44 AM
bryantjt
03-07-2007 03:44 PM
Notstock
09-28-2005 09:40 PM
MAD KAW
09-28-2005 03:39 AM
Quick Reply: handguards don't fit
