Ham radio
Old 05-04-2008 | 10:01 PM
djmerullo's Avatar
Default Ham radio
I am planning on getting my amatuer radio license and I was wondering if anyone has mounted a radio or any other electrnics on there klx. I will post some pics of my set up when I get it done.
Old 05-05-2008 | 02:26 AM
Zen Dude's Avatar
Default RE: Ham radio
That should be intereting to see a dirt bike with a HF radio on the bars
Old 05-05-2008 | 05:16 AM
djmerullo's Avatar
I am going with a yaesu radio from www.aesham.com the one I am getting is meant for motorcycles.
Old 05-06-2008 | 02:09 AM
Zen Dude's Avatar
Get the Yaesu FTDX9000, That would be sweet.
Old 05-06-2008 | 02:24 AM
tremor38's Avatar
ORIGINAL: djmerullo
Most of us only have a GPS, but I see no reason why you couldn't mount a little 2mor 2m/440 dual bander somewhere. I personally think an HF rig and associated antennas would be kinda unweildy though.
Old 05-06-2008 | 03:28 AM
djmerullo's Avatar
well here is what I have planned. Its gonna be a 2m 20cm with a mini magnetic antenna on a bracket mounted onto the license plate. I think that is the most logical place to mount the antenna. and plus all I need is a little peice of angle iron drilled with a 1/4 inch hole to bolt to the license plate then stick my little antenna that I currently have on my truck onto it. the base of the antenna is only 1inch so if I use 2x2 angle I am good.
Old 05-06-2008 | 04:03 AM
tremor38's Avatar
ORIGINAL: djmerullo
Cool! Maybe you can check-in as 'moutain top, off-road mobile' sometime I used to have a modded mobile kenwood dual bander 2m/23cm that I used as a cross-band repeater from my hand held 23cm. I have since let my licenseepire (Extra Class), so I would have tofly to stateside, take the test again, then buy a reciprocal operating permit for another $200.00 here in Japan. Too much trouble to go though right now.
Good luck on the set-up. Post some pics if you go ahead with it.
klx250s_rider
10-01-2013 06:22 AM
redneckaw12
01-31-2008 07:35 PM
stainlessTT
01-24-2008 01:00 AM
stainlessTT
01-23-2008 07:00 PM
markmeinteil
07-27-2006 11:44 PM
