GUess what the dealer mechanic told me today.
Old 07-14-2011 | 05:22 PM
Brewster's Avatar
Originally Posted by TNC
If my thinking is correct, modding the KACR in the manner described allows more compression which causes more vacuum which pulls more fuel and air in such a manner that brings about easier starting? Just to keep things simple, is that about it?
I don't get your reasoning that more compression would result in more vacuum?? The KACR is only functioning during the compression stroke, not the intake stroke.
Ride on
Brewster
Old 07-14-2011 | 06:34 PM
Marcelino's Avatar
I was trying to explain him that taking the long way arround . I think all i did was upset him ( a little )
Anyways the right piece of advice to give in a forum visited by readers with various degrees of mechanical knoledge would be :
Dudes , and of course dudets , if your ACR is messed up don't " fix " your carburator !
Old 07-14-2011 | 09:27 PM
brownie2's Avatar
Thanks for posting guys. I think Marcelino and brewster sum it up well.
I have drilled the "starter jet". I wish I wouldn't have. I don't like the fact that it can't be choked quite long enough now.
I mentioned the cam mod to him and he was very interested. He said just adjust the ACR while I'm in there and be sure to let him know how it turned out for me.
Old 07-15-2011 | 01:49 AM
Ride on
Brewster
LOL!...Yes, I screwed that up. The KACR modification causes higher compression which just takes better advantage of the existing fuel/air mixture. Not sure where I got the thought that induction would be improved. And I wasn't even drinking.
Old 07-15-2011 | 05:11 AM
Blackheart58's Avatar
Do you mean you can't leave the enricher on as long as you used to leave it? So, if you do, it idles a bit too high?
I guess I expect small displacement 4 strokes to have a bit of "personality" when starting...hot or cold, so, it just doesn't bother me. I found what mine likes to do, and I do what it likes. Never turns over more than a time or two without starting right up. I didn't drill my starter circuit...I guess I was lucky.
Old 07-15-2011 | 11:29 AM
ns503's Avatar
I drilled mine - and I'm quite happy with it. It starts way better, hot or cold - and I'm not noticing any problem with it warming up. It may be a bandaid fix to overcome an ACR issue - but it's a damned good bandaid, IMO...
Old 07-15-2011 | 12:43 PM
And, it's easy enough to do at your own kitchen table. I just don't trust a dealership to work on my machines. I've seen too much non-sense going on in those shops.
Old 07-15-2011 | 03:26 PM
Ranger Ron's Avatar
Originally Posted by Marcelino
snip---
And vice versa.
Ron
Old 07-15-2011 | 03:47 PM
linkin5's Avatar
I've ridden form 0 degrees F to 105 degress F and I have no issues starting my bike and I didn't drill any jets when I went stage 2. Just lucky I guess.
deej
05-14-2010 03:49 PM
markmeinteil
04-26-2008 12:47 PM
deej
12-14-2007 07:35 PM
suprakawigrl
05-21-2007 07:52 PM
03-17-2007 06:06 AM
Quick Reply: GUess what the dealer mechanic told me today.
