The Great Humungous
My guess is turn signal will melt....
Mine did within 2 blocks from my house...Idle should be fine but getting up to temp and blowing 5k rpmz worth of heat then idle....Not sure.....
I drilled right behind the tailight...Theres a nice little spot to put some aftermarkets in..
My pipe is a 06 HMF on an 09...Not the same combo....But similar spot when I roasted my signal.........
Rocco
Rocco
Ahh. Well I see that the O.P. simply hacked the bottom off the fender. I am planning on removing it, and fabricating a metal bracket to hold the taillight, signals, and plate. And in doing so, I'm gonna pull in the turn signals. So hopefully whenever I hit the lottery and get a Muzzys I won't roast my signal.
Maybe some of that metallic heat shielding or insulation?
Rocco
Rocco
Less sweep, same width and about 2" higher. I got them in black.
Good point. Maybe it will be OK. I am sure Muzzy tested this. Well, one would hope.
Sounds just about perfect, those stock bars make me feel hunched over when standing and I am only 5' 8". I will look for some this week.
