Gearing Questions - What length chain
Hello everybody I am new to this forum and I am doing some research for a friend of mine to find out the best setup for him to run. He is going to be riding about 90% Dirt and 10% road. Basically riding on the road for 1-2 mile stretches to bridge the gap in the trails.
From reading around on this forum I see that a lot of people like to use
13/45 with 108 Link chain
or
14/48 with 108 Link Chain
(they both work out to be about the same ratio)
Now for my questions.
1. If I go with the 14/48 setup and he decides it is still now low enough and drops it down to a 13/48 does the 108 link chain still work fine with that setup?
2. What is a good sealed chain for this bike. I have to use the DID VT2 on my crf because it was designed for a narrow chain but it's so expensive. There are some cheaper sealed chains out there will they work?
Thanks for your help
-Scott
or
-Scott
Welcome To Kawasaki Forums.
Turn On Some Tunes And Enjoy The Ride.
They're a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometimes It Takes A Little Longer Then Others. So, hang-in there.
48 tooth you will need a 110 link chain regardless of the front sprocket
Awesome! Thanks for your response. I ended up ordering the stuff last night because my friend did not want to wait any longer. Luckily we order a 110 link chain so we are good! Thanks for the confirmation.
This won’t tell you what chain length to buy but will give a good idea on gear ratios.
42/14 = 3 or 3 to 1. This is the stock gearing ratio. Meaning for every 3 full revolution the front makes the rear sprocket will make one full revolution.
42/13 = 3.230 or 3.230 to 1. Meaning for every 3.230 revolution the front makes the rear sprocket will make one full revolution. Or 3.230 divided by 3 (Stock Gear Ratio) = 1.076 or 7.6% gear reduction over stock. So if you are going 40 MPH at say 5000 RPM with stock gearing. With the 13 tooth front the engine will have to be running at 5380 RPM to go the same 40 MPH. 5000 RPM x 7% = 380 + 5000 = 5380 RPM.
42/14 = 3 (Stock)
45/14 = 3.21. 3.21 divided by 3 (stock) = 1.071 or 7.1% Gear Reduction.
46/14 = 3.285 = 1.095 or 9.5% Gear Reduction.
47/14 = 3.357 = 1.119 or 11.9% Gear Reduction.
48/14 = 3.428 = 1.142 or 14.2% Gear Reduction.
49/14 = 3.500 = 1.166 or 16.6% Gear Reduction.
42/13 = 3.230 = 1.076 or 7.6% Gear Reduction.
45/13 = 3.461 = 1.153 or 15.3% Gear Reduction.
46/13 = 3.538 = 1.179 or 17.9% Gear Reduction.
47/13 = 3.615 = 1.205 or 20.5% Gear Reduction.
48/13 = 3.692 = 1.230 or 23.0% Gear Reduction.
49/13 = 3.769 = 1.256 or 25.6% Gear Reduction.
42/14 = 3 (Stock)
Hope someone can help. I have 14/45 and would like to go with some thing higher geared.
I checked RMATV under KLX250s and KLX300 and nothing is listed lower than 45T for the rear.
I looked at some links on this forum but could not see another bike I could put in that would have some bolt up on the rear hub. I would like to get a 43T and also would be interested in buying someones stock rear sproket.
I would like to keep the front stock rather than jump up to the 15T as I understand I may need to do some dremel work to get it to fit.
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
