Gearing 13T vs 14T - speed question
Old 04-16-2009, 03:06 AM
mikey113's Avatar
Default Gearing 13T vs 14T - speed question
I understand that a 13T sprocket will give the bike more throttle response and low end torque but does the bike lose much top end by switching to a 13T? If I am using the bike for commuting, would I be able to hold "a speedometer indicated" 65 mph with a 13T sprocket?
Old 04-16-2009, 03:21 AM
BP88's Avatar
I would also like to know. I plan on putting a DID chain on my bike and may as well drop a tooth since I'm pulling the chain.
Old 04-16-2009, 04:23 AM
SlapDrum's Avatar
If you have it opened up (intake and exhaust), yea.
If not, I doubt it.
When I had the Big Gun System on I think I got up to ~68 with a little more left to go.
I am selling the Big Gun System, any one interested?
It is like new, just to loud for this old Guy
See setup below I gte up to 65mpg with winding it too hard.
Hope that helps.
But I digress.
Old 04-16-2009, 04:24 AM
SlapDrum's Avatar
correction:
See setup below I gte up to 65mpg withOUT winding it too hard.
Old 04-16-2009, 01:47 PM
maineack bob's Avatar
pm me bout that big gun system there slapdrum i may be interested
and i think you ment mph not mpg lol but we all know what you mean haha
Old 04-16-2009, 02:17 PM
Just going down to a 13 on the front and leaving the stock rear alone, you will be fine. I did 700 miles on mine with the 13-45 and at 7,000 I can cruise at 60 indicated (56.4 mph) Slow down and enjoy the scenery.
Old 04-16-2009, 03:23 PM
Chazbo's Avatar
Didn't the 6th gear ratio change on the 2009 so it doesn't have the same "overdrive" of the 2006/2007 models? Like Deej, I changed to the 13T on my 2007 and not only did I get better low end, I also got a very useable 6th gear for off-trail crusing. That may not be the case on your 2009.
Old 04-16-2009, 09:49 PM
doum's Avatar
To me you loose 1 tooth out of 14, so 1/14=7% you just add 7% to your current rpm count at 65mph!
For the same rpm you should go 7% slower, from 65mph to 60.5 mph
So If you can run at 70mph with your 14 teeth you will be able to get to 65mpg with a 13th.
Old 04-17-2009, 02:57 AM
c_m_shooter's Avatar
My 09 holds an indicated 75 pretty easily with the 13 tooth and stock rear sprocket. I have all the usual uncorking mods.
Old 04-17-2009, 03:05 PM
MADDOG07's Avatar
My two cents
2007 KLX 250 NO mods as yet, Using synthetic oil
100mph!
I think it's cause I broke it in w/the "MOTOTUNEUSA" method
http://www.mototuneusa.com/break_in_secrets.htm
I've Got one of BBlue's TM33/34 still in the box. Waiting for my wife to go on vacation. Then the bike can sit in the living room of the apartment while I work on the carb hand guards and a skid plate.
I doubt she'll go much faster but hope it'll get there quicker and with out the 45/50 degree air temp needed for the stock carb to get me (200lbs) to 100mph.
Best o' luck Marc
Quick Reply: Gearing 13T vs 14T - speed question
