gas tank hose dot colors
Old 12-30-2017, 04:39 PM
horror_fan's Avatar
Originally Posted by klx678
I have to tell you it helps if you fill out your profile at least telling what country you live in. There are possibly differences country to country and, in the U.S., between California and other states. When you talk about a manual with only EFI stuff that has to be from any place BUT the U.S. since 2018 is the FIRST year for EFI in the U.S. Having a clue where someone is located helps a lot when it comes to giving advice and tips.
I only remember three lines. There was a line for ON, one for RES (reserve) and a small breather. I am sorry I cannot help with that mass of hoses.
yeah I didn't think they made an 09 that was fuel injected. I was confused about the manual ...but I'm noticing now that it may be for a newer model klx because it doesn't specify a year in the manual. I think I thought it was 09 because the link to download the manual said 09.
I actually downloaded the 09 one from this website as well and couldn't find any thing on the carb ..ill check it again.
located in CA ... my manual was downloaded from the internet.
Old 12-30-2017, 04:40 PM
horror_fan's Avatar
Originally Posted by RaceGass
Wow! Your Fi tank has more fittings than my carbed '09 for sure.
I'm sure whatever info I have probably isn't 100% compatable if your bike was purchased outside the USA.
bought the bike on craigslist in California.
your saying this tank is for FI?
Old 12-30-2017, 04:56 PM
s10gto's Avatar
That is not a FI tank. Yellow fuel , White res. fuel. I only have 4 lines total. Both fuels then one tank vent and one overfill drain. Both gray hoses that exit at the ground. I believe yours is different as 09 had a canister. It was dropped in later years.
Old 12-30-2017, 05:19 PM
s10gto's Avatar
Pic from my14
Some bike **** as it is snowing here and i am bored.
Old 12-30-2017, 05:56 PM
That may be the key to extra hoses. Evaporation pollution stuff that Cal. has and others don't If the charcoal canister isn't there, fumes will possibly vent.out, causing the odor.
Old 12-31-2017, 05:21 AM
horror_fan's Avatar
well.. whatever it is, I've just decided to plug the smelly hoses with Allen wrenches after my rides + let it vent for 5 min outside before I put it in the garage. works like a charm.
Old 12-31-2017, 10:11 AM
s10gto's Avatar
Get yourself a IMS tank and eliminate it. Then all you have is one little vent out the top.
Old 12-31-2017, 06:41 PM
horror_fan's Avatar
na man.. im savin up for a engine rebuild , rings, bearings , valve stems ..etc.
plus I dont want it venting out into my face when I'm riding lol the Allen wrench system is the way to go lol I'm also proud of the system I invented so ... all the more reason to stick with it.
Old 12-31-2017, 08:05 PM
Abramsgunner's Avatar
IMS 3.0 tank rocks... should have come that way from the factory *grin
Old 12-31-2017, 10:44 PM
RaceGass's Avatar
2gallon fuel tank is rather limiting. The 3 gal IMS tank simplifies things, overflow hose one way check valves work excellently $4.95 from rmatv
Brandonbarrett
05-05-2017 09:56 PM
09klx
06-27-2010 09:11 PM
09klx
06-27-2010 09:12 AM
s197richie
06-02-2008 06:47 PM
cdies
Ninja 500R
10-24-2006 11:43 PM
Quick Reply: gas tank hose dot colors
