Fuses
Fuses
Ok I was practicing some bad technique while playing with the headlight wires (trying to install the cyclops as some of you know) I blew something because the headlight doesnt work. I dug a bit in the back and am not finding the fuses! I found one 20 amp fuse but its fine, not sure what its for anyway.
What/where am I looking for for the headlight? the tail light and everything else works fine.
RE: Fuses
I think the fuses are under the seat behind the air box. My manual shows a 20 amp main use and a 10 amp fuse for the fan but I can't find a headlight fuse.
RE: Fuses
Bump!
Ok sorry I'm such a dumbarse, but I'm not finding any of the fuses outside of the 20 amp one. I'm pretty sure I've blown the headlight one. Anyone have a pic where they can show me the location of these stupid things!
Cheers.
Cheers.
RE: Fuses
Do you know how to check the fuses for sure that they work? If you can take them out, get an ohm meter, and put the leads on each end. If you get continuity, it's good, if you don't get continuity, it's bad. Sometimes they can be bad, and don't look it.
RE: Fuses
It's behind the air box on the rear fender, its a small black box with some rubber around it,
there is a spear fuse in it, it took me a while to find it,
i think they are the only two fuses on the bike.
