Fuel bowl screws
Old 08-16-2014 | 05:57 PM
44snot24s's Avatar
well was going strong now its not wanting to stay running it will idle and rev up at first then once you jump on to ride it starts to bog and want to die then kicks in at higher rpms where it runs fine. at first start up theres no black smoke but when it starts to die out and get sluggish has a few puffs. pulled carb out checked everything again took it apart made sure all is clean and in place but still doing it after just got it reassembled. Nothing has changed in there still running the 128 jet and dj needle that was working perfect before with my setup so am i missing something here that i mucked up maybe?
44snot24s's Avatar
also getting plenty of fuel from tank checked lines to make sure wasn't clogged first thing
Old 08-16-2014 | 08:37 PM
44snot24s's Avatar
well starts up and idles ok at first then once clicked in gear and try to pull away it wants to die out pretty much immediately got to throttle it to even keep the bike on but once you let off it shuts right off. looked again all lines are hooked up right and free of anything no harsh bends or anything in fuel or carb lines either. everything on inside looked clean and put new gas in it to just incase that might be issue. still haven't found it yet any input greatly appreciated going to keep trying
Old 08-16-2014 | 10:21 PM
griffo1962's Avatar
Originally Posted by Richard Avatar
I found stainless to be impossible to retrieve with a magnet if I drop one and it's in a hard to reach spot.
must be quite good quality ss then. the lower quality will stick to a magnet..
Old 08-16-2014 | 10:55 PM
44snot24s's Avatar
well its not the jets just went through carb again cleaned pilot out real good and its still bogging down and cutting out ran little better but still same thing.
kojack06
09-17-2012 06:12 PM
clgdswr
09-07-2009 01:10 AM
gybofix
10-20-2008 04:39 AM
fivepointnine
Ninja ZX-7R
14
11-13-2007 08:48 PM
Knivez
09-14-2006 08:22 AM
Quick Reply: Fuel bowl screws
