Frozen ignition switch
So, I generally leave the key in the ignition when I'm at work or home.
Last two mornings, the key and switch were frosty, so frosty you might say it was frozen...pretty solid in fact.
Rolled her into the sun until it warmed up enough to defrost the switch.
Will removing the key stop this?
Never experienced this with any bike. I leave the key in because it's such a pain to put in and take out.
So what do I "lube" it with to prevent this and help the key go in and out?
Put a hat over the dash and key last night to prevent frost build-up, it worked, but the key was still frozen.
TIA
TIA
I know that removing the key can a be a bit of a pain but I say try removing the key overnight. That way the cover can do it's thing and hopefully keep moisture out. I concur on the graphite powder as lube, other substances can gum up the works.
Dan888 for the win!
Last night before I went to bed, I went out and pulled the key out, sprayed the key with some PB Blaster and re-inserted the key, worked it around by turning it on/off, then went to bed.
It's a whopping 15º F this morning, went out and turned the key, no problem! In fact the ignition is smoother than ever, even at 15º!
Blaaah!...even a blind hog finds an acorn now and then.
Here we have a fine example of the main cause of my 99% nonsensical post rate, TNC stirring the pot.
I like to think of myself more like a broken clock. A broken clock is still right twice a day.
Dan
Dan
