Front end dive on hard braking.
Old 01-08-2009, 03:27 AM
ddt1972's Avatar
I left mine all the way in, and put in the .44 springs. Now there is very little dive unless I grab a lot of front brake. The rear shock has two adjusting points, compression at the top and rebound at the bottom where the bolt connects to the swingarm pivot point.
Old 01-08-2009, 03:40 AM
horizonod's Avatar
I'll try mine turned all the way in. Maybe I'll blow a seal and HAVE TO redo the system.
I couldn't find the rebound adjust on the bottom but it's pretty crowded down there. How did you set your rebound once you found it?
Is the rear shock sufficient for a 250 lb rider if the spring is beefed? If so what size or weight spring would be the way to go?
Old 01-08-2009, 07:10 PM
roverdude's Avatar
Originally Posted by ddt1972
+1 on the springs, I have a lot less dive under braking now, going to put in heavier oil to slow down the compression. I only wish there was a way to control rebound like on the rear shock.
To help with the rebound on the front use Moto Pro Suspension part#umax2006k ultramax valve kit 159.95 and 10 wt. Klotz fork oil. Drain the old oil (pump the valve to empty it) and refill to 100mm from top of tube. be sure to pump valve when filling to get an accurate amount of oil.
Old 01-08-2009, 09:54 PM
Beardoge's Avatar
[QUOTE=horizonod;349371]I'll try mine turned all the way in. Maybe I'll blow a seal and HAVE TO redo the system.
QUOTE]
Why would you blow a seal I mean when I floor my car the engine doesn't blow up?
Crank it in that's why the adjustments are there.
Old 01-09-2009, 05:27 AM
MaverickAus's Avatar
talk about front end dive
hows this for some serious front end dive?
Look at his face he knows it's gunna hurt, look at the oil coming outta the fork
Old 01-09-2009, 04:49 PM
horizonod's Avatar
[QUOTE=Beardoge;349542]
Originally Posted by horizonod
I'll try mine turned all the way in. Maybe I'll blow a seal and HAVE TO redo the system.QUOTE]
Why would you blow a seal I mean when I floor my car the engine doesn't blow up? Crank it in that's why the adjustments are there.
Then you haven't floored it long enough.
Anytime you push something to the max it puts preasure somewhere. The valves allow the oil to flow through at a specific rate to stiffen or relax the front suspension. Maxing out the adjustement restricts the oil flow and allows oil to flow through the valves more slowly. Cranked in to the MAX you restrict the flow of oil to the max. If you compress the front end too quickly and the oil has no place to release preasure because the valving is cranked down to it's max it looks for someplace else to release preasure. I'm guessing the next best place for the oil to seek an outlet under extreme preasure would be the seals. Just a guess though.
Just 4 $hit$ n giggles let's test the "flooring my car" annalogy. ( let's assume there is no rev limiter) Screw your idle set screw all the way in so your throttle is wide open, MAX it out, what can it hurt? "Crank it down that's why the adjustments are there". Now start your engine. If there's time before your engine blows pop it in gear.
Lemme know how maxing out the factory adjustable throttle linkage works out for you. You may not blow the engine, right away, but your going to break something be it a simple U joint, your tranny or rear end.
Old 01-10-2009, 04:09 AM
Randy49's Avatar
Thanks for the response horizonod. I'll check mine and see how many clicks till they seat. Rode today, over 700 miles now, felt a little wobbly on the road today, air pressure at 22, maybe to exicted boss let me off to ride before it gets cold. Sure seems to run better after my oil change. Lovin this bike!!
Old 01-10-2009, 04:42 AM
redpillar's Avatar
Have FUN!!!!
phil_r
05-17-2013 04:05 AM
Fentible
06-09-2010 04:18 AM
Ride r
05-30-2010 01:52 PM
mballon
08-17-2007 12:24 AM
goodtimes
11-08-2006 05:30 AM
Quick Reply: Front end dive on hard braking.
