front brake hose...rubbing?
Does anyone else have this issue under braking or any other situation where the fork compresses a decent amount? I fixed it with dome creative drilling and zip ties...
I didn't drill, just a few zip ties fixed mine. I was out riding some very technical stuff and it was rubbing on the tire. I thought the front suspension was really soft. Bike is much quieter now.
ORIGINAL: espacef1fan
Yes I had the same problem, my clutch cable was just about worn through from rubbing on the brake line. I took it back to the dealer and they put a new cable on. The problem was caused because the cables were routed wrong.
ORIGINAL: Marty
WD-40 and Duct Tape
You can fix the world. If it's loose, duct tape. If it's stuck, WD-40!
WD-40 and Duct Tape
Mike
ORIGINAL: YYY.GUY
My toolbox only has 2 things in it: Duct Tape and a condom -- if you can't fix it, f*ck it!
Mike
ORIGINAL: Marty
WD-40 and Duct Tape
WD-40 and Duct Tape
Mike
