Fork and SAE2´5?
Old 12-03-2011 | 01:41 AM
LikesToThump's Avatar
Spot on and good info.
SAE focuses on engine specifications to achieve their rating systems, in addition almost any oil thats SAE will probably have polymers in it to obtain great VI characteristics at a broad range of temperatures... this is cool, but this usually converts the oil from a newtonian fluid to a non-newtonian fluid...
So basically instead of the oil being mostly dependent on temperature for is viscosity factor, it becomes largely dependent on velocity as well for its viscosity factor... this is obviously a poopy condition for your forks on your bike that have ever changing velocity lol
Old 12-03-2011 | 09:37 AM
jeffward's Avatar
An animated video where I do the test suspension. Greetings!
The Kawa is the best dual purpose!
de paseo....jeje - YouTube
Old 12-04-2011 | 05:07 AM
RayCour's Avatar
Wow, an amazing track you have there! Wish I could join...
Old 12-20-2011 | 11:58 AM
grahamgower's Avatar
What a cool track, fast and hard packed. Nice post
Old 03-01-2012 | 05:19 PM
Jeff I am trying to find stiffer fork springs for my weight, 85 Kg, for 2010 klx.
I need 46 rated springs, { I think } Do you have part numbers for the fork springs you are using and where did you order from?
Old 03-02-2012 | 12:20 AM
jeffward's Avatar
I only place I could get was in the Pro Moto
Moto-Pro Suspension
Old 03-03-2012 | 04:21 PM
Thanks Jeff. Do you have a part number? I cannot find on site and these guys do not reply to my e mails.
Old 03-04-2012 | 10:22 AM
jeffward's Avatar
Moto Pro Suspension - Company - Woodinville, Washington | Facebook
tlf. +1 425.844.0661
Do not understand why do not respond to e-business have closed ... maybe?
Old 03-05-2012 | 09:36 AM
OK thanks Jeff. They replied and are sending .42kg/mm stiffer springs. They also suggested a 5.8Kg/mm rear spring. Did you change yours?
Old 03-05-2012 | 02:57 PM
Is your stock spring already a 5.8 or did they change to another rate at some point on the S model?
