Fmf q4
Old 07-14-2013 | 03:37 AM
explorer21's Avatar
Default Fmf q4
I have a 2012 klx with no performance mods done until today. I finally put on my FMF Q4 that's been sitting here since March. The last pipe I put on a bike was in '74 on my 250 F11. Of course I didn't get the gains from this slip-on as I did with the expansion chamber back then. I was debating and researching the install because I really don't want to mess with the jetting. It was really nice to ride a bike that didn't sound like a sewing machine. Love the sound and seems like much better throttle response. The install was very simple and couldn't be happier with it. If I can stay away from rejetting I would like to add the Powerbomb. I ride mostly street and back roads so I don't think I'll be making any more mods.
Old 07-14-2013 | 03:46 AM
Brieninsac's Avatar
If you're going to add a header you might as well open it up and rejet. Then you'll have something a little more noticeable.
Old 07-14-2013 | 04:42 AM
explorer21's Avatar
I am not carburetor savvy so I really don't want to rejet. Can I add the header and not rejet? I don't want to run too lean and ruin the engine.
Old 07-14-2013 | 04:54 AM
djchan's Avatar
This is a good bike for becoming carb savvy. Very simple and it's a crime to not rejet ... even without a new exhaust.
Old 07-14-2013 | 06:20 AM
Karitane Pete's Avatar
If you have fitted the Q4 you are lean already
Old 07-15-2013 | 01:51 AM
linkin5's Avatar
Call FMF see what they say as they'd be the experts for that one. On my bike the stock jetting was spot on with a powercore4 added, I jetted before the powerbomb when I changed the airbox, but if you left the intake side stock it might be fine. The powerbomb made no issues with the jets I had in before the swap.
Old 07-15-2013 | 02:43 AM
wildcard's Avatar
Originally Posted by linkin5
Call FMF see what they say as they'd be the experts for that one. On my bike the jetting was spot on with a powercore4 added, I jetted before the powerbomb but if you left the intake side stock it might be fine. The powerbomb made no issues with the jets I had in before the swap.
+1 if the intake is still stock you are probably ok
Old 07-15-2013 | 11:36 AM
250sf09's Avatar
Honestly, if you buy the dyno jet kit, it will come with instructions on how to do your rejet and it is fairly simple. I think the hardest part is just taking the carb out and then back in. Rejetting is the easy part!
Old 07-15-2013 | 01:48 PM
zippets's Avatar
if he reads the Signatures of people he can get a really good idea on the carb setup
my Q4 is only 86 DB
Old 07-16-2013 | 07:05 PM
Highbeam's Avatar
My Q4 has tested at 96 and even 97 dB once. For crying out loud it says 96DB right on the muffler. You didn't get 86. I like the sound but at times wish there was a god way to bring it down a bit.
Quick Reply: Fmf q4
