FMF Jet Kit
FMF Jet Kit
Hello All, New to this Board.
Have a KLX 250S with Full Muzzy Exaust and Uni Filter. Only 100 miloes on the bike so far.
Looking to put more mods on her. Have a question about the FMF Jet kit for KLX 300.
Has any used one and how does it perform to other on the market?
Thank you much,
Dale
Thank you much,
Dale
RE: FMF Jet Kit
Hey Welcome Dale, I don't know anything about jetting, but I would like to learn more. I had the shop do my Muzzy and jetting, they put in a Dynojet kit, 132 and 40, it runs perfect. Again welcome, and where are you located?
RE: FMF Jet Kit
rassmusan, are you running full muzzy with stock jetting?
If so, you could be running dangerously lean. Have you turned out your pilot screw?
I believe FMF/Dynojet are the same kit... There's another brand out there too - can't recall what the name is...
RE: FMF Jet Kit
Iam running the fmf dynojet kit, I have the stock pilot #24 main and 4th clip down on needle. I also have the full muzzy , uni , and highflow snork, quiet core in. runs great this way for me. at about 1,000 ft. elev.
RE: FMF Jet Kit
Thanks for the Welcome deej, I'm located in Northern, Va
Kawi Wawi, I have not turned out pitol screw, I will now though! Thanks.
This is the air /Fuel Screw mix on side of carb Out to 2.5? Pic?
RE: FMF Jet Kit
I can see that I put #24 main, it should say #124 main. I also turned the air screw out 2.5 turns. http://www.advrider.com/forums/showt...107591&page=37 here's a webpage that shows where the screw is.
slippery750
08-31-2010 10:06 PM
