first, second, then nothing (shift problems)
so today im all stoked, fresh tires, new pipe, im off riding. about 45 mins in, all the sudden i cant go above 2nd. 1st, fine, neutral, fine, 2, fine, after that its like 3rd doesnt exist, the lever just goes up. any ideas, im going to call the shop tomarrow probally.
I did the same as Mudhore. Trying to teach a friend to ride and he dropped it, bent the shifter in and had to bend it out. The only thing is that I couldn't shift to anything at all. Let me know what the shop says punkenduro09 because I am curious.
Interesting someone got a brand new 09 bike because of a similar problem. Wonder if there is a problem with the 09 transmission. I know they changed the gearing a bit but who's had a complete failure with an 06-07?.
I had a similar problem with my 09 from the time I picked it up to its first service. Turns out the shifter lever was loose on the spline. Tightened up and shifts a bit better now. It was popping out of gear all the time, not going INTO gear. It's still fairly rough it seems on downshifting but that might just be me
Does it stay in 2nd or go to a false neutral?
Does the lever move far enough or does it just not click in?
Is it like trying to find a 7th gear, it moves but there is nothing there.
Does the nuetral light work properly?
It sounds to me like you're going inside for this one.
Bent selector fork maybe?
Gears not moving on the splines properly?
Could it be a warranty job.
Check the easy stuff but I think your looking at a tear down and see what you find.
Does it stay in 2nd or go to a false neutral? kinda stays, seams easyer to fall into neutral than normal
Does the lever move far enough or does it just not click in?the lever is making the full motion
Is it like trying to find a 7th gear, it moves but there is nothing there.thats it
Does the nuetral light work properly?yes
It sounds to me like you're going inside for this one. ****
Bent selector fork maybe?****
Gears not moving on the splines properly?doesnt sound good
Could it be a warranty job.not with my local shop
Check the easy stuff but I think your looking at a tear down and see what you find.im ****ed
