FCR 35 and Clarke tank
Old 12-03-2007 | 08:16 PM
jb7's Avatar
jb7
Default FCR 35 and Clarke tank
Is anyone running the clarke tank with an FCR 35 carb installed? I am wondering if there are any clearance issues with the clarke tank as the FCR carb sits differently in the bike than the stock carb. Don't want to buy the tank, only to find out that it won't work for me. Thanks.
jb7
Old 12-03-2007 | 08:46 PM
stellar_d's Avatar
Default RE: FCR 35 and Clarke tank
thats an awesome question. I'm on the fence on getting one too, and i see big bore in my future as well. keep me posted if you find your answer.
Old 12-04-2007 | 03:31 AM
Shadetree's Avatar
I have both carbs. The FCR 35 and Bill Blue's TM 33 bored to 34mm, plus the Clarke fuel tank. The FCR fits fine with the Clarke tank with one small modification. I used a rubber washer to hold the rear of the tank up about 1/4 inch. It was no big deal at all.
I know. You're going toask which carbI like best now.Thejury's still out. I'm sorting out some slight mid range bobbling with the Mikuni, but I like the choke andit's better off idle and tip in throttle. The FCR hits hard in the middle, or seems too, but the dynosuggests that they're both almost identical across the scale. It shows the bobble at tip in on the FCR, which I'm sure I can sort out with a little patience. I just bored the needle jet according to Bill Blue's suggestion, to make it aQO instead of a P8.( #36 drill, .106) Ishould have itback together in a few days to see how it runs with that upgrade.
Hope all that helps.
Bill Dragoo
Norman, Oklahoma
Old 12-04-2007 | 04:37 AM
stellar_d's Avatar
Thanks Bill. Does the TM33 fit with no problems or do you have to do the same remedy for both?
And totally going off topic, it sounds like the carbs are both very similar, and a guy wouldnt go wrong with either?
Old 12-04-2007 | 04:53 AM
MaverickAus's Avatar
The Bill BlueTM33 fits fine with the stock tank, dunno about the clarke
Old 12-04-2007 | 07:57 PM
jb7's Avatar
jb7
Shadetree thanks for the info on the FCR 35/clarke tank fit. I'll go ahead and order up a black(hopefully not leaking) one. Now totally of this threads subject, I'm going to PM you with some FCR questions.
jb7
Old 12-04-2007 | 10:06 PM
mooredan's Avatar
The Bill Blue TM33(34) fits fine with the Clarke tank. The TM36-8012 does not readily fit with the Clarke tank. However, it is easily modified to fit. (need to trim the bell crank and bracket).
toothman32
02-22-2009 06:55 PM
rkutzner
12-20-2007 01:30 AM
plameau
06-29-2007 08:53 AM
mustang
06-26-2007 02:14 PM
Shrumple
06-15-2007 10:34 AM
