The expanding fuel tank.
Old 10-03-2009 | 05:24 PM
I don't think you can get the tank to do anything using hot water and a bicycle pump. Unless you had a hundred pounds behind it.....?????
Old 10-03-2009 | 09:19 PM
09_250s's Avatar
I'm an auto tech, and have heard stories of guys blowing compressed air into the fuel system to find evap leaks then boom. I've learned to be weary of fuel vapor I guess haha.
Old 10-04-2009 | 12:16 AM
clgdswr's Avatar
Couldnt one just empty the fuel out of the tank and drop a match inside the tank. I promise the tank will expand
Old 10-04-2009 | 01:45 AM
tucaz#2's Avatar
i think i got it.
im gonna run a new fuel line to the carb. its gone 3/4"ID. and its gonna run from the tank down the frame, along the swing arm, use some brass fittings to make a 180 back along the swing arm up under the seat out to the rear fender more brass fittings back towards the motor into a brass tube wound in a spiral and then reduced to 3/8" and into the carb. should be good for at least another gallon.
Old 10-04-2009 | 05:09 PM
slippery750's Avatar
Originally Posted by tucaz#2
i think i got it.
Thats my "patent pending" idea! Back to the drawing board.
Warren3000
10-27-2012 11:42 PM
neilaction
08-24-2008 03:36 PM
speed2101
05-20-2006 04:13 AM
jiminwaseca
05-11-2006 07:11 PM
Quick Reply: The expanding fuel tank.
