Engineering Project
#61
It could be controlled with electronically or manually from adj the engine.
#64
It's called fuel induction:
Thunder Products - Performance carburetor and clutching for snowmobiles, motorcycles and ATVs.
#65
#66
I might have to mold a new lid out of part A/B plastic if I just want to use the reeds themselves.
Anyway it seems it'd be a sort vacuum secondaries effect, opening on demand, and potentially tuneable depending on where you put the hold down strip of metal giving the reed more/less flexibility.
#67
I've had the idea of adding reeds to the airbox lid. Maybe make a new same-sized hole as what's there now directly over the filter, and put the reed cage in where the original hole used to be.
#68
There'd still be hole the size of how it came from the factory. So the airbox full of air would be available. For CV carbs the reeds might maintain a slight vacuum.
It'd have to be better than just the original hole in the lid.
Actually I bought a used 8 petal reed cage off eBay and new low-cost OE reeds to fit it. But it's two months before they get here. Hopefully my enthusiasm will hold out for that long. But there's a TM36-68 in the same box, so I may not have the patience to be experimenting with the lid and CVK.
#69
It would be cool to do a project on your own bike. I'm gonna be a junior engineering student and I'm on the FSAE team at my school. I know one of the things our seniors have done is tune the intake and exhaust for our cbr600rr engine. It would be really cool if you could show optimized headers and airbox (if any airbox at all) for the new jetting and pipe you put on. It would be especially cool if you tested if the recommended jetting in the kit is actually optimum for your location and elevation.
Flow optimization would be really cool, and I heard CFD's or any intense FEA usually makes senior projects look really good. Of course your school will need to have an FSAE team with a dyno or you will need to get a local shop to help you out with this one lol.
thanhtruong
02-10-2008 09:23 AM
Daves_636
09-10-2006 11:08 AM
