engine stopped without full choke
Old 10-21-2017 | 06:24 PM
karlcchen's Avatar
Default engine stopped without full choke
My 2012 KLX-250S engine immediately stoped without full choke. It also stopped as soon as I opened the throttle.
The engine is fully warmed up, usually this only happen when engine is cold.
The bike has been sitting for a while, about six months.
Thanks,
Karl
Old 10-21-2017 | 06:39 PM
Brewster's Avatar
Pull the carb and clean it out. Most likely the pilot jet has a restriction in it's little hole.
Ride on
Brewster
Old 10-22-2017 | 12:49 AM
Thumbs up
I don't know, Brewster...sounds more like the starter motor defribrillator solenoid to me.
OP...keep a bottle of Stabil handy if the bike is going to sit that long. Those pilot jet holes hate untreated fuel sitting in there that long. You may need to use a fine wire to clean out the orifice on the pilot jet if it's gummed up enough. Get a spray can of Chemtool B-12 to do the cleanout. Some compressed air to finish things off wouldn't hurt either.
Old 10-22-2017 | 02:40 AM
karlcchen's Avatar
This the first machine I owned that has carburetor.
I will need to learn how to do the clean up....
Thanks,
Karl
Old 10-22-2017 | 03:51 AM
karlcchen's Avatar
Default Why choke stay at full open/close, not half open
Why is my 2009 KLX-250S choke only stay at full open/close, not any where in the middle?
It has been like this since new?
Karl
Old 10-22-2017 | 11:03 AM
durielk's Avatar
it's normal
Old 10-22-2017 | 06:23 PM
Karl
Yeah, it's an annoyance and pretty common on most single carb bikes. My best guess is that it's some kind of "fail-safe" thing to insure the choke stays engaged when you pull out the **** and that it goes completely back in...or shut off...when you disengage it by pushing it in. If it doesn't have a decently strong spring to keep it retained in its off position when pushed back in, it could be an emission issue perhaps, allowing the plunger to creep open causing a rich condition. And then of course, there's the simple issue of it maybe being the cheapest and simplest method of choke operation when manufacturing a carb...completely on or completely off. I know there have been or are some bikes that had a positional choke that would hold, but I never had it on any of the many carbed bikes I've owned over time.
Old 10-23-2017 | 11:36 AM
canklx's Avatar
It'd be a good idea to run the carb out of gas before you store the bike. Not good to leave gas sitting in the carb for too long. I usually put a bit of Seafoam in the tank in the spring with fresh gas to try and keep the feeling system clean of build-up.
Old 10-23-2017 | 07:18 PM
I put one of these on the KLR. It will hold the enricher plunger part-open.
https://www.ebay.com/itm/KAWASAKI-KL...-/122388257050
Old 10-24-2017 | 02:43 AM
If that works as advertised that's pretty neat. Of course, Scott, you always were lazy, so I can understand you not wanting to reach down for the choke twice...LOL!
pvr02
Ninja 250R
08-29-2019 12:05 AM
Captain Kuhle
07-24-2011 05:41 PM
KASHKOW
06-21-2008 04:38 AM
Phase3
11-11-2005 08:18 AM
Quick Reply: engine stopped without full choke
