electric start in gear
I am guessing you may have broke the pin that comes out of the clutch swithc. Easy to do when you are changing out a clutch lever if your not looking out for it. Either way short term fix is disable the clutch switch. I forget if it is normaly open or normaly closed. first try disconnecting the plug. If that does not work then make a conection on across the two wires that go into the plug.
Cheers Jim
Cheers Jim
