Edge tail light kit needs a relay?
Old 03-17-2010, 09:07 PM
Tmoe's Avatar
Originally Posted by frankb
Wich relay or resistor did you put for your blinkers?
And where did you get your electric schema please?
Thank you
I got the blinkers from Procycle. they had relays available so I bought with the blinkers.
Sorry I didnt use a wiring diagram
Old 03-18-2010, 04:17 AM
slippery750's Avatar
I got my kit from Wheeling Cycle too. You do not need any relays for the brake or tail light. The reason your buddy (or whoever he is) said you need relays is to use for the turn signals to put a load on the stock flasher so it does not flash too fast. I would not go this route. Its extra wiring that is not needed to accomplish the same thing the direct plug and play unit that Cycle Gear sells. I forgot whats its called but it plugs directly into your stock wiring under the seat replacing a stock componet (flasher). Good luck.
Old 03-21-2010, 04:56 PM
Tmoe's Avatar
Default oops!
Thank you
Just now realized that I said "relay" in my post when I meant to say "resistor". Sorry for any confusion. I wired resistors in line with the blinkers.
TheBikeRider
11-01-2012 03:23 PM
TheBikeRider
10-07-2012 04:29 PM
rallier
07-11-2012 11:00 AM
punkenduro09
02-07-2009 01:16 AM
RaceGass
10-11-2008 12:34 AM
Quick Reply: Edge tail light kit needs a relay?
