Dynojet Kit: please help!
Old 08-02-2009 | 06:18 AM
kawadude's Avatar
Default Dynojet Kit: please help!
Hi all,
I bought the Dynojet kit to rejet the carb. I'm stuck with the needle part.
According to the instructions for Stage Two:
Install the Dynojet needle on groove #3 from the top. Install the small Dynojet washers above the e-clip.
Problem: the instructions don't say how many washers. They simply use the plural form.
The figure A shows 2 washers. But the kit contains 3 washers.
How many washers am I supposed to use?
Please help!
I need to put the carb back first thing tomorrow morning.
Any help will be highly appreciated.
Thanks in advance!
Old 08-02-2009 | 07:18 AM
slippery750's Avatar
I have the same kit but mine only came with two washers just like the drawing. Mine works excellently with two ontop of the E clip. Drill out that slide hole thats right next to the needle hole since you already have it taken apart. Use a 7/64" drill bit, you will not be dissappointed!
Old 08-02-2009 | 08:27 AM
je2000's Avatar
Don't drill anything before you tell us which dynojet kit you have. That drill bit is not for drilling slide holes.
Old 08-02-2009 | 01:56 PM
kawadude's Avatar
Cool! You should be right, I have checked the instructions for other different models and it's always 2 washers. As in the picture.
They should have got 3 in the kit just to makes sure. The third one maybe it's a spare one.
Thank you so much for confirming this!
Old 08-02-2009 | 01:58 PM
kawadude's Avatar
No worries, the kit comes with a 5/32 drill bit to get rid of the plug on top of the mixture screw. I turn it clock wise until lightly seated and then back 3 turns.
Old 08-02-2009 | 02:16 PM
kawadude's Avatar
Hey I have another question for slippery750: did you have to do a lot of sync once you put the rejetted carb back on the motorcycle?
What do I need to expect. Just readjusting the idle?
Old 08-02-2009 | 04:35 PM
kawadude's Avatar
Blue, yelllow and red tubes under the tank. Which is which?
Old 08-02-2009 | 05:38 PM
cliffsta's Avatar
You shouldn't have to do anything but throw it back on... yeah the idle may need a little adjusting but wait until the bike is fully warmed up to adjust the idle.
Old 08-02-2009 | 05:43 PM
kawadude's Avatar
Mounted everything back. The pipes from the tank were color coded. No problem.
The bike started right away!!!!!
Good sign. Now I'll test ride it. Be back in a while.
Old 08-02-2009 | 06:46 PM
kawadude's Avatar
It runs and feels great. One question though: I switch to Res after only 65 miles. I usually do after 80ish.
I might have lost some gas from the tank during the job. I hope. Otherwise the mileage decrease would be scary.
I put a 124 main jet.
What's your take? How many miles you do with a tank before switching to Res?
Thanks,
Quick Reply: Dynojet Kit: please help!
