Dynojet Help
RE: Dynojet Help
ORIGINAL: MaverickAus
ummm ... its a 250 ... not a 600
RE: Dynojet Help
incabiker,
Basically you can keep dropping hte final drive ratio until 6th gear is the same effective ratio as 5th gear is now. But that means that all of the other gears get lower. If your doing a lot of tight trails, that's great, but if there a lot of road use, too low is not ideal.
I had my bike at 13/45. I went to 14/45 and like it better for all around use. For street use I was shifting too much and 1st was too short.
RE: Dynojet Help
No offense take, like I said I wasn't stating that I wasn't happy with this bike and its performance, I was just saying with others stating there experience with the change in gearing they were able to make 6th gear extremly useful for riding on the highway, and that I need. But if I didn't need it then I would just ignore it. It wasn't that I was being unrealistic, and wouldn't do the change if it wasn't gonna benefit me, but since its gonna make the 6th gear put out more power, then [sm=happy046.gif][sm=yeahsmile.gif]
RE: Dynojet Help
I'm dropping my gearing to 14-45, that way it only drops it a little. It will give me more leverage when I need to loft the front wheel, and also give 6th gear more power but still be a little faster then what my 5th gear is right now. It sounds like a perfect compromise to me.
RE: Dynojet Help
#28
RE: Dynojet Help
ORIGINAL: poodlenuts
what happend to all the dynojet talk?
https://www.kawasakiforums.com/m_29507/mpage_2/tm.htm
1/2" drilled exhaust
Drilled Airbox crankcase vent
snorkle tooken off of air box
Carb mod.
128 Main jet
Dyno needle with e-clip in slot #1 from base
2 1/2 turns out mixt. screw.
Slied drilled with bit from dyno kit.
