Dyno Shoot Out - Megabomb+PC4 vs Stock Header+DG-R
Old 06-06-2014 | 10:47 PM
Klxster's Avatar
Default Dyno Shoot Out - Megabomb+PC4 vs Stock Header+DG-R
Red Curves - Stock Header (port matched) + DG-R Cost: $150.00
Blue Curves - Full FMF, Megabomb + Power Core 4 Cost: $530.00
Test Notes:
The Kustom Kraft Dynojet chart for a stock KLX is a complete Dynojet chart that looks valid. ( http://api.viglink.com/api/click?for...rt_6_22_11.pdf ) It shows the stock KLX at 16.51 hp and 11.69 ft/lbs torque.
DynoJet Dyno, roll-on, runs, SAE CF (which corrects for air temp, humidity, altitude, and engine temp.) Bike was run hot with no tricks to inflate numbers. Runs were only minutes apart -( I changed exhaust systems with welders gloves.) The full FMF system was run first.
Setup notes :
Please see my signature line for the modification status of my bike.
The AFR's are finally within reasonable tolerance for max power production. It took the #132 jet and raising the needle one notch (1 notch lower clip position on the needle ) above Stage 2 instructions to finally stop the bike from running too lean.
Let the analysis begin !
Attached Thumbnails Dyno Shoot Out - Megabomb+PC4 vs Stock Header+DG-R-reddgr_bluefmf.jpg
Old 06-06-2014 | 11:15 PM
durielk's Avatar
For trail riding, I like the red one... and it's 'more economical'!
Old 06-06-2014 | 11:22 PM
Klxster's Avatar
I completely agree - for trail riding, surely Red wins...?
Old 06-06-2014 | 11:32 PM
Klxster's Avatar
So, I'm studying the charts myself.. The stupid simple math - easily repeatable even while snot-slinging drunk - is that the FMF lost about .45 lbft of torque and gained about 1.20 HP over the stock header+DG-R. When drunk, that'll change to 1/2 lb ft and 1 1/4 hp...
FMF has an inferior Trq curve below 6500 rpm - a superior Trq curve above 6500.
Old 06-06-2014 | 11:35 PM
RaceGass's Avatar
But when you drop into the valley and the trail is littered with whoops your gonna want the extra 500 rpms to float the front end down the wash
Old 06-06-2014 | 11:37 PM
Klxster's Avatar
Absolutely right ! The stock+DG-R would let you down , down there. lol
Old 06-06-2014 | 11:48 PM
Klxster's Avatar
Check out how that Red Trq dip - starting at 4900 rpm - coincides precisely with a lean-out "bulge" in Red AFR.
If I could only determine how to stop that lean "bulge" , the Trq curve would certainly go even more in the DG-R favor.
Old 06-06-2014 | 11:51 PM
Klxster's Avatar
Check out Blue @ 8500 rpm... dip in power and a lean bulge there as well.
Old 06-07-2014 | 12:31 AM
RaceGass's Avatar
How many runs of each configuration did you do?
Old 06-07-2014 | 12:33 AM
Klxster's Avatar
He did three pulls on each configuration. So the two runs consisted of a total of 6 pulls.
Quick Reply: Dyno Shoot Out - Megabomb+PC4 vs Stock Header+DG-R
