Dyno results, I'm happy!
Finally got around to putting the KLX and Husky on the dyno recently. The 630 has been a little aggravating (very lean) but I'm tickled with the KLX. All the KLX reviews I've read made me expect 17-18hp but I'm making a little over 20hp. Woohoo! The only mods I've made are turning the fuel screw out 3 turns and adding an washer under the needle. I think it's a little lean on the main but since we're going to the San Juans and Moab later this summer don't think I'll mess w/ it.
Husky and KLX together...
FYI, tach signal is black/green at ecu.
So... this is stock, except for turning the fuel screw out 3 turns and shimming the stock needle???
I'm confused. I thought the stock bike was 17-18 HP. DynoJet claims you can pick up 8% with air/jetting/pipe. You picked up more than that with a shim and a couple turns of a screw?
Not that I'm complaining or anything... Just trying to understand the mods and the numbers.
Ladies, the number is practically meaningless. A dyno is a tuning tool. Unless there is a number (stock bike/modified bike) to compare to, on the same dyno, the gross HP doesn't really represent much, and different dynos will give you different readings.
