DS tires for sandy trails
I live in Fayetteville NC and this region is referred to a "The Sandhills"
Most of the trails around here are very sandy. What dual sport tire is recommended for sandy situations?
Any of you guys have experience in this area?
Pirelli Scorpion XC MS front. DOT legal. Great at 12 to 16 PSI.
Product Description
Pirelli Scorpion XCMS Front Tire
• Pirelli Scorpion XC Mid-Soft Compound Front Tire
• Based on the MT44 front
• The ultimate choice for mid-soft off-road use
• Special polyester carcass for light weight
• Specially designed **** pattern for optimized steering precision and traction
• Conquers everything from rocky terrain to deep sand
• DOT approved
Kenda Southwick II front tyre.
• New design for sand/mud conditions • Front and rear patterns offer tall **** depths for deep bite
• Large radius supports at **** base reduces roll over in soft areas with hard base
• Wide space between rows self clean treads even at slow speed
• Standard race compound allows for increased wear durability and quick
warm-up on cement start pads
• light 4-ply rated casing with reinforced sidewalls
• DOT approved from tire
Product Description
• DOT approved
Yeah, could you clarify your definition of "DS" tire? A true 50/50 tire will pretty well suck in sand. Are you referring to DOT knobbies? A knobby tire will be much better in sand, but some are better than others.
