Draining carb bowl
Draining carb bowl
Sorry for the super-noob question here guys, but can someone fill me in on the procedure for draining the carb?
Just taking my bike out of storage I can't get it to start. I suspect it's because I was lazy and forgot to treat the gas before I put it away for the winter.
Thanks!
Thanks!
On the bottom of the carb, when veiwed from the throttle side of the bike, you will see a 3mm hex screw. Loosen that up and whatever is in the float bowl will drain out the tube...be sure to a container down to catch the fuel.
If you still have trouble, you may have to take the carb out and clean its insides. I 've had carbs sit over the winter and get all gummed up. Only took me cleaning the carb out two times on my old KLR to learn to put Sta-bil in at the end of the season. Hope yours fires right up with fresh fuel.
Dan
Dan
