Drain plug hole is stripped on KLX
Old 10-31-2018 | 01:32 AM
Don Tripas's Avatar
Default Drain plug hole is stripped on KLX
Ive been having a small leak. A drop or two a night since my last Oil change at 18,000 miles. Changed oil again on Sunday at 19,000 and the leak is baad. Pulled the plug out again today and noticed metal in the threads. Through some plumbing tape on it and no luck. Leak is still there.
Any suggestions for the best resolution? Replacing the whole crankcase sounds expensive.
Old 10-31-2018 | 03:34 AM
RageHardIntoTheBendies's Avatar
helicoil will do the trick
Old 10-31-2018 | 02:23 PM
Are you using a new washer?
Sometimes it can be tapped to the next larger size. Or...
Acme or Helicoil or Keensert.
Heli-Coil® | Keensert® | Keysert® | Acme | Comparing threaded inserts
Old 10-31-2018 | 04:05 PM
Don Tripas's Avatar
Prior to Sunday I had no washer. Sunday, I threw a new one in and the leak got worse. I took the washer out yesterday and the leak hasn't improved.
Is the Helicoil a 1 and done process? And can I use the same drain plug? Or does helicoil make the diameter larger?
Thanks y'all
Old 10-31-2018 | 04:41 PM
You can check with a dealer or independent shop. Many have the stuff to do the job, lay the bike on its side, drill or tap to appropriate size, helicoil and done. Grease on the drill and on the tap, slow going and no chips in the engine. I believe it retains the same thread too.
Old 10-31-2018 | 05:19 PM
Don Tripas's Avatar
Just called the local shop. $200 to tap the drain hole. Gahh damn son.
Old 10-31-2018 | 05:34 PM
durielk's Avatar
Or you can do it yourself, drill & tap to new size?
Old 10-31-2018 | 05:39 PM
Don Tripas's Avatar
Man the only thing Ive ever tapped in my life is a$$.
Old 10-31-2018 | 05:43 PM
Don Tripas's Avatar
Seriously though, tapping anything scares me. Ive never done it and the consequence sounds expensive.
.... But doing it correctly myself is the way to go
Old 10-31-2018 | 07:13 PM
Practice on some similar scrap material.
Quick Reply: Drain plug hole is stripped on KLX
