Down shifting clunckiness
Just remember a couple things. If you are going too fast, first gear will be really hard to get into, and if you stop while having not downshifted appropriately then you will have to do the half clutch in and out while holding down on the shifter till you get it into first.
That "clunk" is your selector dogs getting hammered on, and it's abusive especially without synchros to help mesh them. It's also abusive on them to shift without using the clutch, but hey it's your stuff not mine so have fun.
Just think about how fast those parts have to spin to be in 1st gear at high speeds. In my old Toyota 4x4 I had 223:1 for my lowest gear, and coasting down a slope in 1st gear low low could blow up the clutch disk if you go over just a few mph. I don't remember the exact rpms/mph numbers but well over 30,000rpm at the input shaft was easily attainable.
Kind of feels like there is a little confusion.
The clutch is fully engaged rolling to a stop. If I drop more than one gear with the clutch fully engaged the transmission changing gears is a bit clunky.
If I do as suggested and shift one gear at a time while releasing the clutch between gear changes the shifts are fine.
I may be a rolling speed dependent thing but it does seem like it does not like to be shifted more than one gear regardless of the speed.
I do not shift without first engaging the clutch and shifting is smooth other than what I mentioned.
The KLX trans is not nearly as smooth or positive shifting as a Honda.
But,, it seems to be reliable. it just takes some getting use to downshifting a gear at a time while fingering the clutch lever. I sometimes get to a full stop and think i've downshifted to 1st,,, and find i am between a gear or in second.. Def, not a Honda. But,,,,, it works.
EDIT: Perhaps I should not keep the revs so low and shift a bit less around town. I actually like to be around 5k at an intersection so that I can MOVE if I need to.
