Doh!!
Doh!!
First time for me to adjust chain tension/play. Read the manual, etc. I think I've got the "play" good, but would like any tips or techniques you might use to check and verify alignment. The manual say's something about using a string or straight edge? Doh!
Thanks
Thanks
I put a ruler and measure the distance on both sides to make sure my tire is pointing straight and true. Do this at several point and measure. Then measure the actual adjusters. I did it once and it worked out fine. don't get paranoid because then you will imagine things :P
I use the straight-edge method...seems more consistent at the points suggested in the manual. Make sure you check several different places in the chain by rotating the tire a little at a time. Chain slack is seldom perfect throughout the length of chain and neither are the sprockets. Adjust at the tightest point.
pozican
08-18-2007 06:07 AM
