Do pre 2009 klx250 exhausts fit on 2009 and up?
My Muzzy full exhaust I bought used was from a pre-09 "he said " if I remember correctly. He also said it would fit on my 2009. Was he bs-ing me? the numbers on the back of the cone says MZ-0023.
Full Muzzy system uses the DJ144 lidless setup - as will all full performance systems (header + slipon)...
Stock headers with performance slipons use the DJ140 lidless setup..This is regardless of whether you are running a stock KLX300R header or the stock 250 header.
If running a stock 300 system (header + muffler + performance end cap or no endcap), you also use the DJ140 lidless setup..
xmlrider1
07-21-2009 08:32 PM
