DJ 132 Main Jet
RE: DJ 132 Main Jet
sea level i presume? Might be rich but I really wouldnt know. May also want to try moving your needle to #4. I have mine set to that and i'm at 3500ft and it runs good.
RE: DJ 132 Main Jet
at sea level yes. I am running with the airbox lid because i dont notice much difference without it. I reckon the 132main, #4 clip and no lid will do the trick. I also re read the destructions for installing thekit and have left one of the small washers in thelittle clear dynojet box -do you think this is a problem????
RE: DJ 132 Main Jet
I'm at sea level, running the 40 and 132, plus no air box lid, and the 13-45 sprocket setup. The bike is flawless. No hesitation in any gear or any RPM fromidle to 9,000. I went to the 13 tooth as the first mod, but jumped to the full Muzzy, jetting and 45 rear sprocket all at the same time, so it was a hugebump in power. I have not been disappointed. But then again I had a smile on my face the first time I rode the bike right out of the box.
RE: DJ 132 Main Jet
ORIGINAL: stellar_d
deej are you able to get your front wheel up?
Being at 3500ft, isnt super high i guess. I wonder if i should get a 38 pilot and bump up to the 128 DJ
CC_Rider
10-15-2013 03:19 PM
chuck2302
05-14-2008 12:14 AM
