Disconnect TPS?
Old 06-16-2012 | 08:30 PM
When I unplug my TPS, I get an extra 5 horsepower according to my butt dyno.
But yeah, I recall what wildcard is stating on Raycour's findings that it did nothing.
Old 06-16-2012 | 11:55 PM
djchan's Avatar
I've found my butt dyno to be one lying a## dog.
No change - I'll just leave it alone.
Old 06-17-2012 | 04:42 AM
RayCour's Avatar
Yeah, I double checked not so long ago and the TPS has no influence on ignition timing with the carbed bikes (at least, the north american ones).
There is no TPS at all on 09 and later (also, valid at least for NA bikes). The 09 CDI does not even have connections to accept one.
TNC: this does not make your butt dyno invalid. My bike does the same 5hp gain when I disconnect the tps, specially when I'm close to meteorites emitting gamma energy trying to contact aliens. Am I being assimilated?
Wild: what you mean by KTRIC?
Old 06-17-2012 | 04:56 AM
LOL!...I'm telling the truth. You'd better wear a tin foil hat when you get around those meteorites. The buggers will read your mind.
Old 06-17-2012 | 04:59 AM
wildcard's Avatar
Kawasaki Throttle Response Ignition Control
Uses throttle position to enhance "driveability" by varying the ignition timing.
Alot of the carbed kawis had it, including my 6R. Unplugged it long ago and never looked back though.
Detailed write up on my blog if anyone is interested.
The Gates of Dawn: Kawasaki K-TRIC Carb Information
Old 06-17-2012 | 02:50 PM
djchan's Avatar
You're talking crazy now...
Only a SS collander can keep them from reading your mind...
Old 06-18-2012 | 03:23 AM
RayCour's Avatar
Interesting, thanks. Curiously, in the motorcycle world they seem to do the opposite of what's typically done in cars: I'm used to see more timing advance at part load than at full load (read: part throttle, vs full throttle when throttle opening is the only information available to the ecu). From a physical standpoint, the latter makes more sense to me...
Old 06-18-2012 | 03:50 AM
RayCour's Avatar
Not sure if they will find something interesting there
I must confess, since that thread from the meteorite chaser a few weeks ago, I use meteorites presence to explain all sort of things.
dirteater19
04-15-2017 02:30 AM
mhs393
KX250 & KX250F
01-30-2015 01:04 AM
ol guy
12-01-2009 11:15 PM
jman
07-19-2007 04:22 AM
