Disassembling '09 KLX250s Speedometer?
The reset button my 09 speedo has been pressed in too far by the previous owner and no longer lets me reset my trip meter. How hard is it to pull apart the speedo? Im assuming the button has just been pinched underneath the plastic, and ill i need to do is reseat it. Has anyone ever ripped one open?
Shouldn't be hard at all. Just remove the unit from the mount and there are some screws on the backside that hold the two halves together. Remove those and you can gain access to the circuit board and the rubber caps in the face. Just use some care when lifting the halves apart so that you don't lose any pieces-it's not very intimidating once you get it apart. I've had to do the same thing on the head unit for my SV-the rubber caps dislodged.
Oh-and thanks for the pic. I always wondered what the two lens on either side of the key where for.(the carb'd bikes don't light up those spots)
I have never had mine apart, so I only say this from car/truck experience.
If they're anything like the new car stuff there are no real surprises like that. It is just being very careful disassembling. Do not force or pop anything apart unless you are positive it is supposed to pop apart. Most everything should come apart easily when all fasteners are removed. If something doesn't, look for another fastener hidden somewhere or even taped over.
Shouldn't be hard at all. Just remove the unit from the mount and there are some screws on the backside that hold the two halves together. Remove those and you can gain access to the circuit board and the rubber caps in the face. Just use some care when lifting the halves apart so that you don't lose any pieces-it's not very intimidating once you get it apart. I've had to do the same thing on the head unit for my SV-the rubber caps dislodged. Split the halves and lined up the stems again and all is well! Thanks everyone!
jhoffy22
06-20-2011 06:50 AM
