Did they give me the wrong tube?
Old 05-22-2013 | 04:15 PM
DustyCowboy's Avatar
Question Did they give me the wrong tube?
I just ordered a 110/100-18 tire and a 110/100-18 tube
The problem is that tube is stamped as 130/90-18, 5.10-18, 4.5-18 and not 110/100-18 as stated on the dealer sticker.
Do I have the right tube for my tire or should I return it?
Thank you
Old 05-22-2013 | 04:42 PM
There's very little real world difference in most tubes over a fairly wide range of sizing as long as the wheel size is adhered to...at least as it applies to the size ranges you're dealing with here. A lot of tire/tube sizing claims and advertising are often somewhat voodoo-like. With the exception of wheel size, you can see some really different size comparisons even though the tires and/or tubes are marked the same. Don't worry about that tube. It'll work fine with your 110/100.
Old 05-22-2013 | 05:01 PM
Thank you!
I was worrying because last time the dealer gave me a Michelin UHD 18" type B, which was a 130/80-18, to put in my previous 4.6-18 tire.
It resulted in a flat caused by the tube who folded on itself and tore up at the end.
I just don't want to waste more money while risking another flat.
Old 05-22-2013 | 05:06 PM
Originally Posted by DustyCowboy
Thank you!
Yeah, the UHD style tubes are a little more critical as per installation in a smaller tire, but I contend they'll still work if you're very careful during the installation. Powdering up the tube and then airing up and airing down at least once before doing the final air-up and tire bead seating will insure you don't get a troublesome fold in the tube.
cegusman
06-15-2011 06:49 PM
towingjames
10-18-2008 12:04 AM
tkuligowski
800, 800 Classic & 800 Drifter
04-04-2008 02:58 AM
sinkoman
09-03-2007 02:03 AM
txredneckmedic
06-01-2006 09:18 AM
Quick Reply: Did they give me the wrong tube?
