Diaphram in hot water??
OK, about to pull my carb to rejet. I would like to tear it down and soak it in carb cleaning for a few hours, manpybe overnight, but I've read in several other threads that the diaphram needs to soak in hot water while it is put of the carb. Is it going to swell up while I'm soaking the carb and not go back in?
never had trouble with it, just don't lay it down so it;s creased or anything.
Also I would discourage you from bathing the carb in carb cleaner, it's not the old holly and carter afb car stuff of days past. Best to give it a shower with spray carb cleaner, removing the jets and spraying through the passages.
lettin a carb sit apart and soak isn't needed pull it apart clean, jet and get back in the bike i don't soak anything in or on a motor overnight or long periods of tome other than clucth plates
I soaked the carbs on my night hawk.
![](http://i76.photobucket.com/albums/j17/EMS_0525/Nighthawk/NHcarb2001.jpg)
![](http://i76.photobucket.com/albums/j17/EMS_0525/Nighthawk/NHcarbd017.jpg)
![](http://i76.photobucket.com/albums/j17/EMS_0525/Nighthawk/NHcarb2004.jpg)
Best way to clean the carbs with no effort and no mess and no nasty chemicals. Pine Sol. 3 days in 1:1 mix of pine sol and water
![](http://i76.photobucket.com/albums/j17/EMS_0525/Nighthawk/NHcarb2008.jpg)
comes out looking brandy new.
![](http://i76.photobucket.com/albums/j17/EMS_0525/Nighthawk/NHcarb2006.jpg)
To answer original question. I have not had any trouble with the diaphram, i never needed to soak mine. i have had it out many times. on my KLX, my buddies, and my KLR.
![Wink](https://www.kawasakiforums.com/forum/images/smilies/wink.gif)
Thanks guys. I'm gonna dunk it in my gallon bucket of carb cleaner at least for an hour or so. I just thought I might tear the bike apart one night and get it soaking then reassiemble the next night. BTW, in one of the write-up's on here someone estimates 6 hours to rejet and install foam filter, snorkel and slip-on?? The pipe took me five minutes so 5+ hours to pull the tank, carb, clean, rejet, etc. seems excessive. Just want to know what I'm getting in to so I have enough time to complete. Estimate for first time rejet?
