Delicate operation: rusted screws on front brake cylinder
Hey group
Just bought a 2006 klx250. Not a mechanic. Front brake is going all the way to the grip so I'd like to dig into the cylinder and see what's going on in there. The screws on top are rusted to the point where my first attempt at muscling one off resulted in a slight stripping of the screw head.
Before I start in with the normal rusty screw removal regimen wondering if you folks can tell me anything about how delicate that lid is. And if there's any better way to get in there then diving into the normal tactics.
Thanks for any advice!
-roccit
-roccit
NOTE: those aren't Philips head screws they're JIS. Filing down the tip of the proper size philips will approximate a JIS driver, best is to get JIS screwdriver.
Discrete use of a quite small and well sharpened cold chisel after soaking with a good penetrating oil should get that stripped one out.
MC cover screws are CS, nothing to grab......
Anything you can stick in there that can be picked out easily.
If you get the black oxide screws you need to do this, black oxide will often easily rust - as those black oxide coated screws on Kawasakis have proven. I use the bright zinc (silver) plated screws wherever possible to avoid corrosion. I don't do stainless, with rare exceptions, due to the need to coat the threads to avoid the thread metal fusing seizing the fastener in place - which can be a disaster. A good hardware store may carry the zinc screws needed or see if a local Fastenal will sell them by the piece. I know they sell SAE by quantity packages, but with metrics I think they sell by the piece. Other hardware sources may do the same.
I need to take the screws out of my reservoirs and replace them when I install the braided lines. I'm thinking it's M5-.8 x 10, but best to measure the screw to be sure.
