Cutting out in 1st & 2nd
Old 05-08-2012 | 02:26 PM
rcraig's Avatar
Default Cutting out in 1st & 2nd
Hey All,
I have a 2009 KLX 250s bone stock. It has been flawless and has 15000 miles on it. Recently it has begun to run erratically in 1st and 2nd gear. It feels like it is cutting out, losing power, and jerking from power loss, not surging. It only does this in the first two gears, but I think I feel it starting to creep into the higher gears as well.
Has anyone else experienced this, or have any idea what could be causing it?
Thanks for any help.
Craig
Old 05-08-2012 | 03:07 PM
Pogiboy's Avatar
My money would be your carb. Needs to be cleaned. One of the jets or needle has partial obstruction.
Old 05-08-2012 | 05:33 PM
cmott426's Avatar
Slipping clutch
Old 05-08-2012 | 07:04 PM
Blackheart58's Avatar
DINGDINGDING! Clean them good while you are in there, you don't want to have to do it twice.
Old 05-08-2012 | 08:23 PM
MaverickAus's Avatar
sidestand or clutch switch?
Old 05-08-2012 | 08:53 PM
rcraig's Avatar
Looks like I will have to do process of elimination. Start with carb cleaning, if that doesn't fix the problem move to the clutch plates. If the problem was one of the safety switches I would think it would manifest itself throughout the gears.
Thanks for the feedback.
Old 05-08-2012 | 09:03 PM
ahnh666's Avatar
the bike won't start at all...or, just shuts down instantly...i had kill switch issues on my bike before...
Old 05-09-2012 | 02:55 AM
2veedubs's Avatar
15k miles? When was the last time you checked the valve clearance?
Old 05-09-2012 | 03:19 AM
rcraig's Avatar
Uhhh.... never. How often should that be checked?
Old 05-09-2012 | 03:27 AM
2veedubs's Avatar
Funny
Quick Reply: Cutting out in 1st & 2nd
