Custom programmable CDI for the KLX
Hello all,
It's been a long time since I wrote here, I've been busy. Among other things, we design application specific CDI units in our company. I've always wanted to install one on my KLX (which is already quite modded... ).
I also stated a long time ago on this forum that if we could get the same connectors as on the KLX CDI, it would be a simple matter for us to offer a commercial plug&play programmable CDI unit. Well, that happened last November. So, after a few months on the drawing board and some validations, we'll offer a commercial replacement CDI for the KLX at the beginning of March. Express your interest if any, so that we know how many units to build this month! I don’t want to use this forum for commercial advertising, it is probably against the etiquette. We have web pages being designed that will go online early next week. Yet I can’t resist giving here some of the details. Please see it as informative purpose, not marketing.
The custom CDI will be available only for 06-07 model year at first, and should be available for 09 and later in April. This is only for the north american and australian KLX (though australians might not have strong interest since their CDI is already more aggressive). It will be $219 plus shipping.
The commercial unit have small ears on the side that permits bolting it in place of the stock one.
The circuit is an adaptation of previous designs that made their proof in past projects:
The commercial version is pottied with silicone and able to withstand harsh environments.
The custom programmable CDI has a "MAP select" connector: leave it open to select the stock timing curve of the north american CDI (25deg advance@5000rpm)
or install the supplied short and get the australian (is it the “KLX250ES”?) curve (35deg@5000rpm):
These are rather crude timing curves, if you ask me, but this is what those stock CDI do. If you look closely, the unit has a led on the top. It blinks when the engine is not running: blink slowly when the 25deg. Curve is selected, fast when 35deg.
Or spend $60 more and get the CDI to PC link device for full programmability, including the ability to set the cutoff at the rpm of your choice:
It will be pottied in a small plastic box. It plugs into the USB port of your computer and works with our proprietary software. You will even be able to program timing curves that depend on throttle opening (3D mapping), if you want so:
What is the gain going from 25 to 35deg advance? I don't know for sure, and honestly, it might be not very much. I saw mentioned on this forum 0.5hp gain by switching from north american to the australian CDI (the one with 35deg advance). Anyway, we'll know exactly when temperature gets above freezing point here. I have reserved dyno time early in March.
Hmm... i would be interested
BUT i would rather see it come with the AUS map for the default and a custom more aggresive (but safe) map as the second option.
two hundred and fifteen bones is alot of money to throw at a half a horsepower if that is indeed the gain from 25 to 35 degree advance with the only other preset map being the same as stock. If i want the crappy stock timing back i'll put the old CDI back in .... lol
Also i don't really understand how the 3d mapping is going to work without a TPS ? I know the older bikes had them but all the new ones do not.
You're right, 3D mapping is only going to work with 06-07 models. No TPS on 09 and later bikes. Strange path for Kawasaki, if you ask me... The TPS had no influence at all on the CDI, even though it was connected to it.
