cs sprocket removal
RE: cs sprocket removal
I had the same problem. I just ended up with my air hammer with a dull chisel and hit it once on the back side of the nut (larger part). Brrrrpp! Came right off with no damage.
Hope that helps,
db
Hope that helps,
db
got r done...bought a 18-inch strongarm, 1 1/16 inch impact socket (6-point) and a can of liquid wrench..left the bike off the jack until I had the nut loosened..I think that helped some too..friend sat on bike, brake on and CRACK it finally came loose...took it for a ride on some tight trails, hills, roots, rocks, etc and loved it. really a big difference off road and as I read more power to accelerate up the hills..thanks guys for the advice
OK, I think that my CS nut was probably on as tight as anyone could ever get it.
Actually, I have had the nut off before when I swapped the stock 14T for a 13T -- and I know that I torqued it back on to spec.
So now I want to go from a 13/42 setup to a 14/49 setup, so I'll put the stock 14T back on. Got the new rear 49T and a new chain and proceeded to take off the front nut. NO WAY. I tried everything:
- putting a 3/8" ratchet extension over the swingarm and through the rear sprocket -- ended up indenting the swing arm and bending the rear sprocket after using a six foot piece of conduit over a 18" 1/2" drive breaker bar
- went out an bought a 300 ft-lb capable electric impact wrench - didn't have a 6 pt. socket and ended up rattling much of the chrome plating off of the socket
- got a big buddy to sit on the bike, standing on the brake --ended up being able to overcome his weight and the brake with the 6 foot extension
Decided that I wasn't going to get it off the normal way. Remember that the nut has sort of a flange on the back side of it?
I figured that I could carefully cut off the flange with a cutting wheel on the dremel tool to relieve the pressure.
With that thought in mind, I ordered a new nut and washer because I'm going to destroy them.
I saw that the parts will arrive tomorrow, so proceeded with my surgery. It went suprisingly well and took only about 10-15 minutes to cut off the flange. I was really suprised that after doing this the nut spun by hand!
The photo shows that I cut the washer too, but I really didn't need to. I didn't hurt the output shaft or anything else.
Now how in the world did it get so tight?????
I have a theory. Some of you may remember my mudhole incident, where a rock got lodged in the rear chain guide and I ended up spinning my clutch.
https://www.kawasakiforums.com/m_141059/tm.htm
I figure that the while the wheel was locked up, the engine, with its full torque, tightened that nut up before moving on to and destroying the clutch.
Anyway I got it off now and will get the new gearing set up soon.
More fallout from the mudhole event. While swapping the rear sprocket I discovered that the chain adjuster got mushed. Either this happened then or while I was trying to get the CS nut free. Note the deformed number 5 and circle cutout.
I used one of these and it knocked the nut loose in 2 seconds. No damage. I tried with a 1/2 impact and breaker bar and wife holding brakes etc with no luck. You can get a cheap air hammer chisel.
Hope that helps,
db
Hope that helps,
db
Yeah, I thought about that too.
I measuredthe runoutwith a dial guage and found it to be around 0.040" (~ 1.0mm). The standard is a runout of 0.8mm (0.031") with a service limit of 2.0mm (0.078").
Thanks for the QA check. (Quality Assurance)
cyrjordan3
09-25-2009 04:51 AM
